LabWindows/CVI
FileExists function - odd behavior in CVI2017
In moving from CVI2015 to CVI2017, the ToolsLib FileExists function returns error -93 when file to be verified is over 3 Gbytes in size.   Files to be verified of considerably smaller size yield the expected return of '1' .   Perhaps the ssize_t calculated output parameter of this function is blown,  but using the function's instructions to ignore the calculation of this parameter still results in error -93.  CVI 2015 had no issue with verification of large size files.  ..This a bug?
(2,538 Views)
Yes, it is a bug that has been fixed in CVI 2019.
(2,470 Views)
Accepted by Steve_Macha
Is this a bug that lies inside the Run-time Engine? That is: if I run my 2017 executable against the 2019RTE will this bug disappear?
(2,464 Views)
Roberto you are correct, the bug lies inside the Run-time Engine and running the application on CVI 2019 Run-time Engine should solve the issue.
(2,436 Views)
Hello @Razvan_P,
I see the same issue with CVI RTE 2019 (version 19.0.0.49154) and for a file that is less than 2 MB large.
I started having this issue after I ugraded the RTE from 2015 SP1 to 2019 (without upgrading my application, which is developed with CVI 2015 SP1)
Vix
In claris non fit interpretatio
Using LV from 7
Using LW/CVI from 6.0
(1,554 Views)
