LabWindows/CVI
FileSelectPopupEx dialog box doesn't display the file type
When I bring up a file selection dialog using FileSelectPopup and ask for files with a specific extension, the dialog box displays the extension correctly in the "Files of type:" ring control.  When I use FileSelectPopupEx, the ring control is there, but it's blank.
The attached screenshot shows the difference.
I'm running LabWindows 2015 f1 on Windows 7 Professional.
Message 1 of 10
(4,771 Views)
I just tried it out on my computer and it seems to work fine.  Could you try reproducing the code below?
Message 2 of 10
(4,717 Views)
I copied your code onto my PC and built it.  It's still giving me the same problem.  I tried using all four build configurations (Debug, Debug64, Release, Release64) with the same results.
Message 3 of 10
(4,713 Views)
That's certainly pretty strange.  Could you try it out on another version of LabWindows/CVI and see what happens?
Message 4 of 10
(4,682 Views)
I just tried it on a different PC running CVI 2013 SP2, also with Windows 7.  The same result happened.
Message 5 of 10
(4,678 Views)
Strange.  I've tried it out on a buddy's computer and it worked fine for me.  Could you attach a screenshot of the exact code and the file popup?
Message 6 of 10
(4,643 Views)
Here are the screenshots.  The code should be identical to the one you gave me to try.
Message 7 of 10
(4,639 Views)
Accepted by richferrara
I've taken a closer look into it and it seems like this is a known issue and there is a Corrective Action Request currently filed for it.  You can track the number 414667 in product updates to see if it has been addressed.  Thanks for bringing this to my attention!
Message 8 of 10
(4,610 Views)
How do I track it?  I looked through the known issues list for CVI 2015 but I don't see that number.
Message 9 of 10
(4,606 Views)
You will see the number tracked in product update posts.  In the release notes it will reference the CAR number if it has been addressed.
Message 10 of 10
(4,587 Views)
