LabWindows/CVI
Flip a vertical pointer slide?
Is there any way to create a vertical pointer slide with the tick marks on the right side instead of the left?
(3,165 Views)
Accepted by richferrara
I'm not aware of any way to do that!
A (complicated) workaround could be to hide control tick marks and place a graph side by side with the slider. Hiding all elements of the graph other than the right axis elements you could have more or less what you want, but the slider needle will still point leftwards.
I am attaching the .UIR file in case you want to take a look at it.
(3,129 Views)
I was mulling over the question and got mentally stalled.
Maybe it is only me, but why would I waste my time with something like that? 🙂
(3,089 Views)
This is just a cosmetic workaround if you need the ticks to be on the right. No need to worry about it if you are okay with the tick marks on the left.
Maggie M.
Application Engineer
National Instruments.
http://www.ni.com/support
(3,068 Views)
