Dear community,
I am making Labwindows CVI application which need to be started as Graphical User Interface if there is no parameters and in Command Line (no UI) is there are some parameters.
So in the "BUILD" / "TARGET SETTING" menu, I set the "Create Console Application" item.
But when I launch the application with no parameter, I have a "console windows" that appear.
How would you do to avoid starting that "console window" or close it?
Thanks for your help.
Serge
