08-02-2017 08:13 AM
CVI 2015f1 GUI Localization Utility - using text message controls
Labels and titles all seem to localize properly, however the Text Message default string content does not as it it remains in the default language at runtime. Is this intentional? If I have to instead programmatically set a string value for this type of control then text message content must then be handled 'dynamically' rather than 'statically' for localization. Is there another workaround for the default message content?
08-03-2017 11:03 AM
Dear Steve,
I was able to add a text message string and quickly create a new .lwl file (I went off a shipping example) and it converted over no problem. Are you sure everything in you .lwl file is in order?
