09-29-2021 04:00 AM
I'm experiencing issues with an IVI Driver, the SorensenDC one that i use to control a SGI Series DC Power Supply from Sorensen.
When I try to run the initialization function, a General Protection fault occurs.
My IVI Configuration seems to be fine (attached pictures), even when i select "Specific Driver" in the "Simulate With" field, this error occurs.
(The logical name ALIM_1 is well associated with the Sorensen SGI Driver Session.)
Maybe I'm missing a point.
Thanks for your help.
Enzo Langevin
10-04-2021 06:51 AM
Hello any update please ?
11-04-2021 03:37 AM
Have you tried to create basic app using Sorensen driver? There is no information regarding that error codes.
As I understand you also have error message in NI MAX. can you share the screenshot?
11-04-2021 03:57 AM - edited 11-04-2021 03:59 AM
I had no error message in NI MAX.
In the case expressed in the initial post, I had not received the Sorensen power supply. When I received it I ran the TCP/IP visa resource search in the network devices tab in NI MAX. After that I did not have this problem anymore.
However, in my opinion, there is still a problem with the driver in "simulation" mode. Why can't we simulate a power supply, as we can do with a DMM or other instrument ?
(Even if specified "Specific Driver" in Driver Sessions for my Sorensen driver session)
12-17-2021 01:32 AM
