04-18-2011 10:12 AM
I am trying to generate an analog output for the following waveform:
Pulse width: 300 usec, Frequency 40 Hz, Amplitude is following a sine wave with a 2 second period.
My approach is: Use an async timer with 1/[40 Hz] sec interval. I set the DAQ output rate at 1 MHz and the approach has been to generate and write 300 samples of the amplitude I need to send out, then wait for the next async interval callback , update amplitude etc etc. The assumption is that once the 300 samples are written and the task started , a 300 usec pulse would be sent out , task then stopped and then the analog output would be set to 0 waiting for he next pulse. The reality is that I get a stream of pulses of 300 usec which last the whole timer interval.
So , trying to establish whether what I am trying to do is feasible without actually sending a large array to the USB-6251 which would write zeros for the period after 300 usec.
Here is my timercallback code for review:
switch (event)
case EVENT_TIMER_TICK:
DAQmxErrChk(DAQmxStopTask(TaskAnalog));
Determine Voltage value algorithm here
//Generate Waveform and start Task
//Prepare AO arr
for (k=0;k<300;k++)
AOArr[k] = 0;
if (k<G_PulseWidth)
AOArr[k] = VOLTAGE_OUTPUT;
if (AOArr!=NULL)
DAQmxErrChk(DAQmxWriteAnalogF64 (TaskAnalog, (int32) 300 , 0, DAQmx_Val_WaitInfinitely, DAQmx_Val_GroupByChannel , AOArr, &sampsPerChanWritten, NULL));
DAQmxErrChk(DAQmxStartTask(TaskAnalog));
break;
04-18-2011 10:26 AM
I did resovle the issue I encountered. It was due to bad configuration of the Task.
My initial configuration was:
DAQmxErrChk(DAQmxCfgSampClkTiming(TaskAnalog, "",1.0E+06, DAQmx_Val_Rising, DAQmx_Val_FiniteSamps , 300 * 1.0E+06));
which should be:
DAQmxErrChk(DAQmxCfgSampClkTiming(TaskAnalog, "",1.0E+06, DAQmx_Val_Rising, DAQmx_Val_FiniteSamps , 300));
THis did it. works very well.
THanks
