LabWindows/CVI
How to Change Modes(like MaxHold or FM Dev.) on E4440a (Spec.Analyzer ) remotely
I need to chande meauring modes while running my test procedure software using an E4440a spectrum analyser
specifically MODE - Measuring Receiver - FM Deviation
there exists no such mode changing commands on the driver how can i deal with it?
Thank you
Levent ;
(2,760 Views)
Hi Levent,
What version of the e4440a driver are you using?  Unfortunately the IVI drivers for this device are not supported.  That being said, have you tried looking at the e4440 programming manual?  I found a copy of the manual here, and after a quick search found the command MRECEIVE is used to change the measurement mode to Measuring Receiver.  I hope this helps.
Ted
Message Edited by Ted H on 11-13-2007 02:31 PM
Ted H
Applications Engineering
(2,735 Views)
