LabWindows/CVI
How to change Command Button Press color
How can I change a command button color when it is pressed and held?
i.e. I want it to turn green momentarily while being pressed.
Thanks.
(4,441 Views)
In my opinion the best option you have is to use a toggle button, painted in the desired colours in the two available states. In the callback of the button set its value to 0 immediately before exiting:
SetCtrlVal (panel, control, 0);
Proud to use LW/CVI from 3.1 on.
My contributions to the Developer Community
________________________________________
If I have helped you, why not giving me a kudos?
(4,437 Views)
I tried that but the on color does not show up because it is too fast.
(4,424 Views)
Respond to EVENT_LEFT_CLICK_UP
Guillaume Dargaud
http://www.gdargaud.net/
(4,402 Views)
The visual state of the controls is not updated while inside the callback: that is why you don't see the control in ON state. Insert a ProcessDrawEvent ( ) as the very first instruction in your EVENT_COMMIT callback, next proceed with the rest of the code. You will see at lease a flash of the ON color.
Tell us if the ON state time is too short so that we can suggest some additional hint.
(4,380 Views)
Accepted by NI Nubie
The EVENT_LEFT_CLICK_UP achieved the desired effect. The toggle button now displays the 'On' colour until the button is released.
Thanks all.
(4,377 Views)
