LabWindows/CVI
How to maximize a panel and its controls?
I set panel`s attribute in the "Other Attributes" section of the Edit Panel dialog.
When the panel is maximized, its controls cannot scale up, so I got a very discordant interface.
I want to know whether there is a way to get a coordinate interface after maximization?
Thank you.
(3,283 Views)
Accepted by topic author weikui1313
Adjusting CVI panels depending on screen size has been discussed several times in the forums: one of the last discussions is this one.
I agree with you that a brute resizing gives poor results so I always ask myself which element of the panel actually need to be resized and how much. Personally I do not rely on automatic resizing: I use the splitter way to adapt panel aspect to screen size, but I normally do not enlarge buttons and texts.
(3,279 Views)
Thanks for your help, I try to adjust it according to your way.
(3,269 Views)
