11-29-2011 11:08 PM
I want to search an examples in ni.com through NI Example Finder,But the "ni.com query timeout" indicator always turned on after I checked "include ni.com examples" in NI Example Finder, so I have to find this example in NI website,but still can not find, do you know how to find below example:
NI Example Finder\Hardware Input and Output\Instrument Drivers\IVI \ividmm.prj.
Thanks!
12-01-2011 01:55 AM
Hello, if you install NI DMM module, this example will be installed in your disk, and you will find it in NI example finder without using include ni.com example checked. For "ni.com query timeout", there may be many reasons, you can refer the following link:http://digital.ni.com/public.nsf/allkb/BB4F052E48D9476186256FFD0067A992?OpenDocument
12-01-2011 07:00 AM
but could you tell me the link to download "NI DMM Moudle"? or the link to example code "ividmm.prj".
12-01-2011 07:41 PM
12-05-2011 10:41 PM
Thanks,but after install the NI-DMM 2.0,I still can not find the ividmm.prj in CVI8.0 NI Example Finder
(NI Example Finder\Hardware Input and Output\Instrument Drivers\IVI \ividmm.prj.),and aslo not found this example in directory \Program Files\National Instruments\CVI80\samples\NIDMM.
could you tell me where I can download this example in NI website?Thanks
12-08-2011 07:59 AM
who can answer my question?thanks.
12-12-2011 04:06 PM
On my system, I was able to locate it under this location:
C:\Documents and Settings\All Users\Documents\National Instruments\CVI\samples\IVI\IviDmm\
Hope that helps,
JB
12-12-2011 09:01 PM
Thanks, you are right,this example will display after install IVI Compliance Package ,it has nothing to do with the NI-DMM which someone suggest.
