LabWindows/CVI
How to solve Error 206009 ?
Hello
Without any modification of my usual CVI software, I have the following error that suddenly appeared:
Status Code : -89130
Device not available for routing. It is possible that the device needs to be reset or that the device is being reset. If you are resetting the device, wait for the reset to complete. For example, if you have used the device through Traditional NI-DAQ, you must reset the device before the requested route can be made.
I tried to solve this through Measurement and Automation Explorer by resetting all my devices. It just changed the error printed by CVI to :
Status Code : -200609
Error code -200609 Generation cannot be started, because the selected buffer size is too small.
Increase the buffer size
Selected buffer size : 1
Minimum required buffer size : 2
I found a 14 years old topic with the same error, but no solution there : https://forums.ni.com/t5/LabWindows-CVI/DAQmxWriteAnalogF64-Generation-cannot-be-started-because-the...
Thank you very much
System configuration
CVI version 9.0.1 (375)
Windows XP
MAX version 4.6
My NI devices are :
- NI PCI-MIO-16E-4
- NI-PCI-6534
- NI-PCI-6733
- NI-PCI-6733
(988 Views)
(979 Views)
Accepted by topic author Luclucluc
The problem has been solved. There was in fact 2 issues :
  1. The NI devices had crashed.
  2. A config file used when the software starts was lacking.
The solution is as simple as a reboot + restore the config file !
(944 Views)
