LabWindows/CVI
I need help to use EPP as In/Out data lines
I have seen that there is not library for communication through parallel port. I need to used it but I cannot find information about how to proceed or an example using the PP with LabWindows, just for LabView. I would really appreciate any kind of information that you could tell me.
Thanks a lot.
(2,818 Views)
There is a library to do this, it is under Ultility/Port IO library. The inp and outp functions allow you to write directly to and from the port.
Info on paralel port addresses etc is available anywhere, like here http://www.beyondlogic.org/spp/parallel.htm
Dave 🙂
(2,800 Views)
