LabWindows/CVI
In CVI2013 'portable projects' need a rebuild
although the below reported bug may be covered by his may not be obvious so I wanted to share it with you in case you were venturous enough to upgrade to CVI2013...
I work on the same project on two different computers and thus transfer all related files back and forth, i.e. the *.c, *.h, *.ico, *.uir, *.prj and *.cws files. In the past this was working more or less ok, with CVI2013 it fails: if you have a newer UIR file CVI2013 will not use it but the one in the CVI build folder... so one has to use the 'rebuild' menu command, the standard 'build' button is not sufficient, you will see the old UI...
(4,254 Views)
Hello
(4,239 Views)
Accepted by Wolfgang
Hello
(4,231 Views)
Thanks!
(4,225 Views)
