11-07-2007 03:55 PM
11-08-2007 11:43 AM
11-08-2007 11:44 AM
11-09-2007 08:07 AM
11-09-2007 12:28 PM
Hi Rob,
Based off your screenshot, I am assuming that you are not using the
LabWindows/CVI Real-Time Module. Is that a correct assumption? The reason I ask
is that LabWindows/CVI 8.0 introduced direct download support for LabVIEW
Real-Time for Pharlap. This behavior has changed for LabWindows/CVI 8.0.1
because LabWindows/CVI now provides support for the LabWindows/CVI Real-Time
Module. See the KB LabWindows/CVI
8.0.1 Requires the LabWindows/CVI Real-Time Module to Downloads DLLs Directly
to Real....
If I understand correctly, when you installed LabVIEW 8.5 and the LabVIEW 8.5
Real-Time Module, you were unable to see the LabWindows/CVI Run-Time Engine for
RT item in the LabVIEW Real-Time Software Wizard dialog that is launched from
Measurement and Automation Explorer? However, you could see this item on the
other target? Could you post a screenshot of what you see on that new
target in that dialog?
What version of LabVIEW and LabVIEW Real-Time did you have installed before
LabVIEW 8.5?
Best Regards,
11-21-2007 10:19 AM
11-21-2007 04:15 PM
Hi Rob,
Yeah, it doesn't sound like your using our CVI Real-Time Module. Thanks for clarifying that. I also see that you have called into our support team as well and have them working on your issue as well. Its probably best if we keep the issue in one place so I'll let everything go through our support team and then trickle up if needed.
Just a couple of questions though. On the target that you don't see CVI on, I assume you see other software that you can install like LV RT? If so, can you successfully install those components and boot up the target without errors? If you could install the software, did you try going back into software wizard and seeing if then you could see CVI?
Are the boot disks that you are using new or old boot disks? By that I mean are you still using boot disks that you made in LV 8.0.1 or are these new boot disks that you made with LV 8.5? If you are using old boot disks, have you tried creating new boot disks and then trying to use those new ones?
Best Regards,
11-22-2007 08:45 AM
11-22-2007 09:42 AM
11-22-2007 12:12 PM
