01-13-2009 03:33 AM
01-13-2009 03:50 AM
01-13-2009 03:59 AM
01-13-2009 04:01 AM
01-13-2009 10:35 AM
01-13-2009 11:11 AM
Hello Pims,
Would it be possible for you to strip down your program, preferably eliminating any dependencies on hardware, and post here a version of the program that reproduces this hang?
Luis
01-14-2009 03:02 AM
01-14-2009 11:01 AM
Knowing that the hang doesn't happen if you don't plot to the stripchart is helpful but it's not enough to guess what the problem is. Hopefully you'll be able to strip out the dependencies and send us the program. Does your program use more than one thread, by the way?
The logs that you attached could potentially also be helpful, but it looks as if the ones you attached here correspond to the CVI environment, not to your program. To get a log of your program instead, run the ConfigCVILogging utility, but at the top-left of the window select Runtime Engine instead of Environment.
Luis
01-16-2009 04:37 AM
