LabWindows/CVI
Labwindows CVI and debugging MSVC++ dll
We are using a DLL written LabWindows/CVI  as code module for Teststand . This DLL calls a DLL written in MSVC++.  Is there any chance to use  the Labwindows/CVI debugger to debug into this MSVC++ DLL ( if this MSVC++ DLL is build with the "right" options) ?  Or is this possible only using  the MSVC++ Development environment ?
(3,774 Views)
Accepted by mkossmann
Hello mkossmann,
CVI's compiler generates different type of debug info than MSVC.
The CVI debugger doen't understand debug info generated by MSVC so you can't debug the dll compiled in MSVC.
Constantin
(3,757 Views)
