LabWindows/CVI
Launch application on remote PC by CVI
How to launch application on remote PC?
(3,228 Views)
Unfortunately, CVI doesn't have any built-in features that allow for remote executable launch from one PC to another. Therefore, your best options will be looking into whether or not Windows can do this. After doing a quick Google search, it seems that one way is to create a "Program Launch" Windows Service that runs in the background on the slave machine. It will accept TCP connections and expects a string that contains the executable name and arguments.
Here is a link you may be interested in: http://www.codeproject.com/KB/system/remoteexec.aspx
One advantage of this solution is that it will be very flexible in that it is not limited to CVI programs. At the end of the day, CVI is not running a server in the background for this explicit purpose.  However, CVI does support remote debugging, which you could possibly use to do something similar to what you are attempting to do.  An article on how to use the remote debugger can be found here:
http://zone.ni.com/devzone/cda/tut/p/id/3384
I hope this helps clarify things!
Shelby S
Applications Engineer
(3,204 Views)
Accepted by dtadenev
I’ve solved the problem using telnet.
Thank you very much,
dtadenev
(3,199 Views)
