Hi Ted,
This is exactly what I am trying to do i.e. to create a DLL from function panel. The piece of code where I am using the MessagePopup function is shown below:
int at71612a_check_instr_error_status (int instrumentID)
char *token;
if (at71612a_invalid_integer_range (instrumentID, 1, at71612a_MAX_INSTR, -1) != 0)
return at71612a_err;
Fmt (cmd, "%s<:SYST:ERR?");
if (at71612a_write_data (instrumentID, cmd, NumFmtdBytes ()) != 0)
if (at71612a_read_data (instrumentID, cmd, 200) != 0)
token = strtok (cmd, ",\n");
Fmt (&at71612a_err, "%d<%s", token);
token = strtok(NULL,"\n");
Fmt (errorstring, "%s<%s\n", token
if (at71612a_err != 0)
MessagePopup ("AT 71612A", errorstring);
This is the only function where I am calling the MessagePopup function.
I am not sure why CVI is giving me the Link error although it is compiling perfectly.
Can you throw some light on what are the reasons when CVI gives Link Errors?
swhamid
