LabWindows/CVI
Link error: Undefined symbol '_GenCosWin@16' referenced in "af3030.c".
    I am using an eval copy of CVI 8.5 awaiting my full license.
I have been building my project fine with no errors. Now I am failing to build with this link error.
I have reverted my code so I am back to where I was getting successful builds - still get link error. I have commented out the code that references this gencovwin, and it builds with no errors.
gencoswin is part of the CVI analysis.lib, which I have in the folder C:\Documents and Settings\All Users\Application Data\National Instruments\CVI85\bin\msvc
Will a full license fix my problem?
Rik
(2,991 Views)
Have you explicitly added analysis.lib to your project?
You have to do this for every lib you use
Vix
In claris non fit interpretatio
Using LV from 7
Using LW/CVI from 6.0
(2,987 Views)
Thanks - that is what I figured out before your reply - that fixed it. Thanks
Rik
(2,985 Views)
