LabWindows/CVI
NI_CAN (0xBFF62002) internal error occurs in the NI-CAN driver
I have some trouble with my PC enviroment
As let me guess that NI-CAN driver cannot open device.
I already installed lastest NI-CAN driver version.
and attach my Error log.
please give me feedback ASAP...
(2,545 Views)
I haven't been able to gleam much information from the error log alone. Therefore I have some questions and also would like to collect some further files and information:
1. Have you previously been able to use your CAN device?
2. Are you working from a CAN example?
3. Does a crash actually occur, for instance, do you see something similar to the below image:
https://www.codeproject.com/KB/debug/597856/AccessViolation-DLL.PNG
4. Does this work in the development environment but not the executable form?
Could you also provide an NI MAX Technical Report so we're familiar with what  NI hardware and software you have installed on your system. To do so you can create one given the steps below:
http://digital.ni.com/public.nsf/allkb/271F252B4EF0A2E0862570E70056A1E4
Please note: select Technical Support Report.
Additionally could you provide the code for which you are running into this error?
Ed
(2,451 Views)
