LabWindows/CVI
Network Variable string array
Hi all
I am working on a project that would require one program to talk to another program(same computer), hence the use of the network variable.
Now say I have a list or table of names that changes in one program, what I would like to do is take parts of the list that is in one program and transfer certain parts of the list to the other program.
The list needs to be able to transferred with at least 40 single names of different size with letters.
I have the data arrays ready I just need to figure out the transfer part.
I tried the 3D.sim but there seems to be a problem when I am using strings especially when the strings are different lengths.
Also when using the CNVCreateArrarDataValue errors on the array value occur being to small on the array size?
Array listings of strings are usually 2D (Row, and size) does this factor in??
Assume network variable is declared
exp code just to get the idea...
int i=0, numItems=10;
CNVData data=0, NVlist[120]={0};
size_t dim={0};
size_t dim2={0};
for(i=0;i<numItems;i++)
   char listName[20]="/0";
   GetTabelCellValue(panel, PANEL_LIST, MakePoint(2,i), listName);
   dim[0]=strlen(listName);       // i tried size_of but that definalty makes the dim to big
   CNVCreateArrayDataValue(&NVList[i], CNVString, listName,1, dim)    /////i keep getting array size issues here
   dim2++;
CNVCreateStructDataValue(&data, NVList,dim2)    ///here is another issue with dimensions
CNVPutDataInBuffer(Handle, data,2000);
i also tried
   GetTabelCellValue(panel, List, MakePoint(2,i), listName);
   CNVCreateDataValue(&NVList[i], CNVString, listName)
   dim2++;
CNVCreateStructDataValue(&data, NVList,dim2)    ///one string value transfers
i think i am close but jsut cannot get the right sequenceSmiley Sad
Thanks ahead of time
(4,331 Views)
lriddick,
It looks like listname is just one string, not an array of strings.
Humphrey H.
Applications Engineer
(4,309 Views)
i see the confusion you are mentioning i was tyring to give a free hand code snipit
lets say i have an array
char listName[10][20]
listName[0] ="dog"
listName[1] ="bulldozer"
etc...
Now how do i get the network variable Array or struct to be sent with all the values listed (dog , bulldozer, )
(4,304 Views)
What happens if you just send one string at a time and add it into the array on the reader side rather than sending the entire array at once?
Humphrey H.
(4,286 Views)
Accepted by lriddick
lriddick,
You can write an array of strings easily, but it must be an array of strings. It can't be a two-dimensional array of chars, which is not the same thing. For example, the following code should work (I replaced your table with an array called "table" but the rest should be the same). Note that I only create a single CVNData, not an array of CNVData's:
    char *table[] = {"one", "two", "three", "four", "five", "six", "seven", "eight", "nine", "ten"};
    char *listName[10];
    CNVData data=0, NVList;
    size_t dim[]={10};
        listName[i] = malloc (strlen (table[i]) + 1);
        strcpy (listName[i], table[i]);
    CNVCreateArrayDataValue(&NVList, CNVString, listName, 1, dim);
        free (listName[i]);
    CNVPutDataInBuffer (handle, NVList, CNVWaitForever);
(4,217 Views)
thanks...
that worked
(4,193 Views)
