LabWindows/CVI
PCIe-653x with traditional DAQ
we want to upgrade some of our existing system with a PCIe-6536. Is it possible to run this card with traditional NIDAQ?
Does anybody have experience with PCIe-653x with traditional DAQ. Or is it only possible to run this card with DAQmx?
Greetings
Oliver
(3,110 Views)
Accepted by topic author OZI
Hi Oliver,
PCIe boards are generally not supported by the old traditional DAQ driver.
Anyway you should consider updating your application to DAQmx, as the trad. DAQ support is pretty limited (see also official statement from NI below)
"Caution  Traditional NI-DAQ (Legacy) is an older driver with outdated application programming interfaces (APIs) for developing data acquisition, instrumentation, and control applications for older National Instruments DAQ devices. You should use Traditional NI-DAQ (Legacy) only in certain circumstances. Refer to the NI-DAQ Readme for an overview of the two NI-DAQ APIs, the advantages of NI-DAQmx, and more information about when to use Traditional NI-DAQ (Legacy), including a complete list of supported devices, operating systems, application software versions, and language versions. You can install the latest version of NI-DAQmx software, available at ni.com/downloads"
Bernd
(3,092 Views)
Hi Bernd,
thanks for the information
Greetings
Oliver
(3,086 Views)
