LabWindows/CVI
PXIe-5423 Channel Error
Greetings:
I am using Labwindows CVI with a PXIe-1085 Chassis and a PXIe-5423 Card.
I recently installed the driver for the card and am attempting to generate a waveform.
I do not understand how the channels should be named ie "CHANNEL1", "CHANNEL2"...
I am getting a channel error.
Here is the code:
Code to create the waveform here.
ViReal64 arbWaveForm[32768];
for (int i = 0; i < 32768; i++)
ViStatus viStatus = 0;
ViSession ViSessionAWG = 0;
ViInt32 ViSessionAWG_WaveformHandle = 0;
ViChar ChannelName1[64] = "";
ViChar ChannelName2[64] = "";
//Initializes and checks the state of the drvioer to be sure its the correct instrument driver for the instrument.
//Resets the PXIe-5423 40MHz 16Bit AWG
viStatus = IviFgen_init("ni5423 (2CH)",VI_TRUE,VI_TRUE, &ViSessionAWG);
//Gets the PXIe-5423 40MHz 16Bit AWG Channel Name.
viStatus = IviFgen_GetChannelName(ViSessionAWG, 1, 64, ChannelName1);
viStatus = IviFgen_GetChannelName(ViSessionAWG, 2, 64, ChannelName2);
//Sets the PXIe-5423 40MHz 16Bit AWG for an Aribtrary Waveform Output.
//Also could use IVIFGEN_VAL_OUTPUT_SEQ
viStatus = IviFgen_ConfigureOutputMode(ViSessionAWG, IVIFGEN_VAL_OUTPUT_ARB);
Crashes here due to unknown Channel?
//Creates the PXIe-5423 40MHz 16Bit AWG for an Aribtrary Waveform Output Waveform.
viStatus = IviFgen_CreateChannelArbWaveform(ViSessionAWG, "CHANNEL1", 32768, arbWaveForm, &ViSessionAWG_WaveformHandle);
Any ideas on what I am doing wrong?
Thanks.
(953 Views)
Accepted by topic author codehawk
I tried the niFgen functions instead and now do not have the channel errors anymore.
(925 Views)
