LabWindows/CVI
Question with Function GetCompName();
I am having some trouble when try to use the 2013 CVI function.
in the main routine I include the hearder file of GetCompName();
#include "toolbox.h"
defined the variable with
char ComputerName[MAX_COMPNAME_LEN];
and in Main.c I just put GetCompName(ComputerName);
but I keep getting the error message:  error: Undefined symbol '_GetCompName@4' referenced in "f:\XXX\Test\cvibuild.test\Debug\test.obj".  everything is fine if I comment out the section of GetCompName(ComputerName);
Is there anything I missed?  Or is it because the system have compatible issue? I am using Windows 7 64bit environment.
(5,644 Views)
this function GetCompName() belongs to the Programmer's Toolbox, so you need to include the respective include file
include <toolbox.h>
(5,638 Views)
Hi Wolfgang,
Thank you for the reply, I did include the library before using it with #include "toolbox.h"
But the error remains.
(5,636 Views)
Accepted by Silverwolfman
You also will need to add the library to your project. This can be done in two ways:
- Use the Library / Customize menu to add \toolslib\toolbox\toolbox.fp to your libraries
or
- Use Edit / Add Files to Project to add toolbox.fp to your project
(5,634 Views)
Thank you for the help!
That works.
(5,628 Views)
My pleasure Smiley Happy
(5,617 Views)
