LabWindows/CVI
RS-422 PPS Signal Generation
I'm trying to generate a RS-422 PPS signal using the PXI-8431/8 PXI board, LabWindows/CVI and the standard CVI library functions but I can't find a way of producing a signal that remains HI persistently for X number of ms.  I realize that using the PXI-6602 would be an ideal solution but for my case I'm relying on the RT OS to maintain determinism.  Do you know of a white paper or discussion thread that might describe a reliable way of doing this with the CVI functions and serial boards I have?
This post was copied from the LabView discussion board.  Sorry for the inconvenience.
Message 1 of 9
(5,851 Views)
I do not believe that there is a way to do this. The driver doesn't support the toggling of the lines, especially with the accuracy you would need. It would be best to use the PXI-6602 card for this. Have a great day!
Best Regards,
Adam G
Applications Engineer
Message 2 of 9
(5,818 Views)
So I've got my hands on the 6602 and am looking for example code to get me started, but all I can find are dated version (5.5 or earlier).  Is there anything current that could offer some guidelines for generating the PPS?  Specifically, I'm using a RT Hypervisor controller and building an RT application.
Thank you for your help.
Message 3 of 9
(5,803 Views)
Hi There,
Assuming you're using DAQmx and you want to generate a continuous pulse train (hardware-timed), you can find examples that do exactly this by looking in: Start » All Programs » National Instruments » NI DAQ » Text-Based Code Support » Ansi C Examples » Counter » Generate Pulse.
Hope this helps!
Sean
Sean Ferguson
Application Engineering Specialist | RF and Reconfigurable Test
Message 4 of 9
(5,779 Views)
I tried the files you recommend (plus some other examples from various locations) and I keep getting a series of error messages:
Undefined symbol '_RegisterWinMsgCallback@24' referenced in "dataacq.lib".
Undefined symbol '_UnRegisterWinMsgCallback@4' referenced in "dataacq.lib".
Undefined symbol '_GetCVIWindowHandle@0' referenced in "dataacq.lib".
Some files that the example includes are:
NIDAQEX.C
NIDAQEX.H
These all go away when I boot into Windows.  I have loaded the Real-Time module and am using a RT Hypervisor controller.  Could I be missing software or be using a Windows library when a RT lib is available?
Thanks.
Message 5 of 9
(5,767 Views)
One additional note:
I can include dataacq.h in my RT application code and it compiles fine.  I begin seeing errors when I add the CVI function from the Traditional DAQ library, ICTR_Setup().
Message 6 of 9
(5,749 Views)
Hi JMK,
You can use DAQmx or TDAQ, not both. I would strongly recommend DAQmx since TDAQ is no longer supported.
Sean
Sean Ferguson
Message 7 of 9
(5,736 Views)
Accepted by topic author jmk75
Sean,
I updated the pulse generation functions with those from the DAQmx library and am now up and running.
Thank you so much for the input.
J
Message 8 of 9
(5,729 Views)
Hey Jmk,
Glad to hear it. Happy coding!
Sean
Sean Ferguson
Message 9 of 9
(5,693 Views)
