05-30-2017 10:05 PM
I writing an application to write 60 Hz analog output signal to 9 channels. I picked 400 as the number of samples (
numSampsPerChannel) . I calculated the sample_rate using the relationship
numSampsPerChannel = sampleRate * (1/ frequency). I calculated a sample_rate of 24000 which I used as input to DAQmxCfgSampClkTiming functions. I used 400 as the number of samples per channel. I used the code below to get my data. When I plot the data for one channel, the 400 samples corresponds to only one sine wave. I had expected 60 sine waves which I thought was calculated using a one second interval divided by 400. To get the full 60 cycles, I need to set numSampsPerChannel the same as the sample_rate. I thought I had to follow numSampsPerChannel = sampleRate * (1/ frequency). When is this formula applicable? The program runs and does not complain about setting the sample_rate the same as numSampsPerChannel.
for (; i < numSampsPerChannel; i++) { for (; j < numChannels; j++) { offsetIndex = phaseOffsets[j] * PI / 180.0; if (j == 1) { data[j * numSampsPerChannel + i] = amplitude[j] * sin((double)i*2.0*PI / (samplingRate / sineWavefrequency2) + offsetIndex); } else { data[j * numSampsPerChannel + i] = amplitude[j] * sin((double)i*2.0*PI / (samplingRate / sineWavefrequency) + offsetIndex); } } j = 0; }
05-31-2017 02:10 AM - edited 05-31-2017 02:12 AM
The behaviour is consistent with your code. Your expectations are not correct.
Generically;
numSamples = sampleRate * timeInterval
(note: the unit of sampleRate is samples/sec)
If timeInterval = (1/frequency) = period = ~0.01667 sec, then you acquire a period length of samples, which is obviously a single sine cycle.
If timeInterval is 1 sec, you get the number of samples requierd to acquire 1 second length of samples. Which includes 60 cycles, because your signal is 60cycles/second.
When timeInterval is 1 sec, numSamples becomes equal to sampleRate.
So theory matches with your experience. You should reconsider your expectations.
Hope this helps,
