LabWindows/CVI
SetMenuBarAttribute
Bonjour,
Je veux mettre comme visible un sous item d'un item. J'utlise SetMenuBarAttribute. La question, qu'est ce que je dois mettre comme 1er et deuxième paramètre: le menubar ou le item parent ?
Cordialement.
Message 1 of 10
(3,656 Views)
Bonjour,
this question can be answered by looking at the help, e.g. here
menuBarHandle is the first parameter, the menu item the second
Message 2 of 10
(3,651 Views)
it's not an item but un child of un item, then, i wonder about if i have to put the bar menu or the the sub item as first parameter.
Message 3 of 10
(3,646 Views)
Accepted by FibiIA
Excuse moi,
my french isn't good enough to have realized the difference...
For submenues, the first parameter is the same menubar handle that you obtain from LoadMenuBar, the second parameter is the menu item id as assigned in the User Interface Editor, e.g. MENUBAR_ITEM1_2_ITEM1_4_ITEM1_14. It works both for menu items and submenu (child) items.
Message 4 of 10
(3,642 Views)
well, it doesn't work, see:
SetMenuBarAttribute (MENUBAR_EM_MENU_SUPERUSER,MENUBAR_EM_MENU_SUPERUSER_ITEM_SUPRESS_ITEM_SUP_CARTE,ATTR_DIMMED, 0);
the error:
NON-FATAL RUN-TIME ERROR:   "authentification.c", line 47, col 13, thread id 0x00001168:   Library function error (return value == -4 [0xfffffffc]). Panel, menu bar, or control array handle is invalid
Smiley Frustrated
Smiley Embarassed
Message 5 of 10
(3,639 Views)
How does your call of LoadMenuBar look like?
It should have some similarity with
panel_handle = LoadPanel ( 0, "my_gui.uir", PANEL );
menubar_handle = LoadMenuBar ( panel_handle, "my_gui.uir", MENUBAR ); Could it be that you confused the menubar_handle with MENUBAR?
Message 6 of 10
(3,636 Views)
I used the variables that i found in the .h file of the GUI see:
SetMenuBarAttribute (MENUBAR_EM_MENU_FILE, MENUBAR_EM_MENU_FILE_ITEM_IMPRESSION, ATTR_DIMMED, 0);    //this one works because it's an item,
i didn't use the menubarhandel, just the the menubar name in the .h file
SetMenuBarAttribute ( MENUBAR_EM_MENU_SUPERUSER_ITEM_SUPRESS_SUBMENU,MENUBAR_EM_MENU_SUPERUSER_ITEM_SUPRESS_ITEM_SUP_CARTE,ATTR_DIMMED, 0);//this not because it's subitem
Message 7 of 10
(3,633 Views)
Why are you averse to use the menubar_handle? I would assume that by chance your MENUBAR_EM_MENU_FILE has the same numeric value as the menubar_handle, and that's the reason why this line works...
Message 8 of 10
(3,630 Views)
ok, it works, i just put MENUBAR_EM_MENU_FILE as a handle, seams that it took it as a handle of the menu bar because it's the first one.
Thank you, i appreciated
Message 9 of 10
(3,626 Views)
Très bien!
Message 10 of 10
(3,623 Views)
