11-05-2013 06:54 AM
Why does NI Update Service not remove unnecessary files after finishing?
Every time NI Update Service is updating software it creates a directory National Instruments\Installers with the extracted download. This may well be several hundred MegaBytes. After updating installation these files are not used anymore. They could be deleted automatically...
11-05-2013 08:18 AM
Is it caching the download in case the files are needed to create a distribution in CVI? Just a thought...
11-06-2013 03:01 AM
Hi
you can find the answer for this question in this threat:
Is it safe to delete old Update Service installers? - NI Discussion Forums
http://forums.ni.com/t5/LabVIEW/Is-it-safe-to-delete-old-Update-Service-installers/m-p/2513294
Regards, Stephan
11-06-2013 03:29 AM
Thanks!
My extracted summary:
These folders should not be deleted for patches until a new (full) release is installed.
Since those folder names are not self explanatory it might be best to choose a drive with less space constraints, using menu File >> Preferences
Maybe NI can also consider providing (an option to) automatic clean-up.
