LabWindows/CVI
Snap graph cursor to nearest visible plot
In LabWindows/CVI, it is wonderful that the user can use the graph cursor to snap to the nearest data point.  But my graph contains both visible and invisible plots.  I want the graph cursor to snap to the nearest data point of a visible plot only, ignoring the invisible ones.  Advice?
Josh Moses
The Modal Shop
(3,543 Views)
Josh,
You can configure whether a cursor can snap to a particular plot by setting this plot attribute:
SetPlotAttribute (panel, graph, plot, ATTR_PLOT_SNAPPABLE, 0);
I might have expected hidden plots to not be snappable by default, but apparently they're not, so you'll have to also set this attribute whenever you hide a plot.
Luis
NI
(3,541 Views)
Great!  Thanks so much!
(3,536 Views)
