LabWindows/CVI
Status Bar in LabWindows/CVI
         I'm new in LabWindows/CVI. Is it possible to compose a status bar, like in C#, in LabWindows/CVI? Moreover, how can I place the buttons, that I composed before, onto the tabs or decoration tools?
         Good days...
(5,310 Views)
You can either use a horizontal level slide as a quick and simple solution or use the more advanced custom control Progress Bar
(5,307 Views)
If you are intending a ribbon at the panel footer where to show informations and optionally add buttons, at present CVI does not have such a control.
It has a toolbar control, instead, so if you can reverse your design so that a toolbar can be used, you can find the control into <cvidir>\toolslib\custctrl\toolbar.fp
There is also a demo project that you can look at: you can find it with the example finder (Help >> Find examples... menu function).
(5,304 Views)
too tired to distinguish tool bar and progress bar... Smiley Embarassed
(5,301 Views)
...but there is a suggestion to implement it here, you may want to support it...
(5,283 Views)
Too tired to remember all pending suggestions on CVI... even if I already suppoerted it! Smiley Wink
(5,277 Views)
