03-02-2009 03:13 AM
I am currently migrating a project to CVI 9.0 which worked fine with the last version (was it 8.5?)
Now i am facing some trouble with thread safe queues.
I am (according to the return code, successfully) installing a TSQ callback with CmtInstallTSQCallback, where I pass the name of my CVICALLBACK callback function. The callback was intended to read items from the tsq, while data is written asynchronously to it. This writing happens at quite a low frequency, and there is a processSystemEvents() in the main function of the same thread, which is actually called.
Now the problem is that the callback is never executed, so the TSQ runs into an overflow quickly. I don't know if I am missing something, are there any major changes to thread-safe queues in the new CVI version?
If it helps - I am working on a PXI 8196 RT target with LV RT 8.6 and the CVI runtime engine and CVI network variable engine or RT 9.0 installed.
Any help is greatly appreciated!
03-02-2009 06:35 AM
