LabWindows/CVI
Tab Control Defines
I have two tab controls on my main panel, both are loaded with the same uir which gets the same controls and callback functions.
When I execute the same callback from the different tab controls i get
panel = 4 control = 93 from the 1st tab control and
panel = 13 control = 93 from the 2nd tab control.
This is what I was expecting.
The control is defined in the .h file for the uir as  #define  LASER_SEED_ENABLE                93
My question is are there define constants that I can use for the panels (4 and 13)?
How does the tab control determine the panel number?  Is there an include file or is the panel number determined at runtime?
Message 1 of 10
(4,501 Views)
you should better not use constants because every time you edit the UI you are at risk that the assignment of control/panel id's is changed. At run time, you can obtain the panel handle of tab panels using
GetPanelHandleFromTabPage ( main_panel_handle, PANEL_TAB, 0, &tabpanel_1_handle );
Note that control ids are not unique, only the combination of panel id / control id is.
In the UI editor, you can use the menu View / Preview User Interface Header File.
Hope it helps.
Message 2 of 10
(4,497 Views)
Wolfgang,
That is my worry that the panel numbers will change from 4 and 13 depending on editing the UI.  I need to make a decision based on whether the panel is from 1st tab control or the 2nd tab control.  I don't want to code if(panel == 4).   I want to code something like if(panel == TAB1PANEL).  That way if UI is changed, I don't have to change the code.
Message 3 of 10
(4,493 Views)
Yes Smiley Happy
But why don't you like using GetPanelHandleFromTabPage? It can tell you the tab panel handles for all your tab panels at run time; call it when your program starts up, after loading the UI. You can then use if ( panel == tabpanel_1_handle ) as requested...
Message 4 of 10
(4,489 Views)
The values I get from GetPanelHandleFromTabPage are 113930140 and 1600061440.  How do they compare with 4 and 13 from the panel variable in the callback function?
Message 5 of 10
(4,487 Views)
Does it make any deference that I am using easytab.fp to create the tabs?
Message 6 of 10
(4,485 Views)
yes, it does... Sorry, I have assumed you're using the native tab controls. Let me suggest moving your code...
Message 7 of 10
(4,483 Views)
I used to do the native code, then I from the easytab.  Let me convert it.
Message 8 of 10
(4,479 Views)
Wolfgang,
Moving the code back to the native tab controls work.
Thanks for your help.
Paul
Message 9 of 10
(4,446 Views)
You're welcome!
Message 10 of 10
(4,442 Views)
