LabWindows/CVI
Thermotron 8800 control using LabWindows/CVI 2017
I am writing some code to control a Thermotron 8800 controller from LabWindows/CVI 2017. In the past I have used a "TH8800" driver from NI/Thermotron. When I search through the Thermotron website it seems like the only NI drivers available are LabVIEW.
When I try using the older "TH8800" drivers, I cannot compile because they rely on the old "cvirt.dll" that is no longer supported in CVI 2017.
Does anyone know of a recent Thermotron driver for the 8800 that compiles in CVI 2017? They provide C++ "drivers", but these do not have a function library but rather just show how to communicate over TCP with custom strings based on the protocol defined in the users manual.
Or does anyone know where I can download "cvirt.dll" to try the fix listed here:
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019PZhSAM&l=en-US
Many thanks!
(2,940 Views)
Accepted by WeMul12
I do not know if that file can be found anywhere on NI site, but you can find attached a copy of it found on my machine for you to try.
Proud to use LW/CVI from 3.1 on.
My contributions to the Developer Community
________________________________________
If I have helped you, why not giving me a kudos?
(2,921 Views)
This seems to allow me to compile and run with the old drivers. thanks!!
(2,887 Views)
cvirt.dll war removed from CVI installer but it is available for download at http://www.ni.com/download/labwindowscvi-run-time-engine-2017/7888/en/
(2,827 Views)
