LabWindows/CVI
Undefined Symbol = NiFPGA_ReadSgl
I have a LabVIEW FPGA program that has a SGL indicator on.  I am trying to use LabWindows to read that indicator using the function NiFPGA_ReadSgl.  LabWindows gives a link error of "Undefined symbol" as if the library does not have the code, but the NiFPGA.h file has it defined.
Is this a future upgrade or is the library corrupt?
(3,558 Views)
C API supports SGL types (see http://www.ni.com/tutorial/53283/en/) so not sure what the issue is.
ALE Consultants
(3,554 Views)
Terry,
I get this
Build Status (95002 Innovate Test Diagnostic.prj - Debug)
 95003 FPGA Support.c
 Link 95002 InnovATE Test Diagnostic.exe
  error: Undefined symbol '_NiFpga_ReadSgl' referenced in "x:\Engineering\Engineering Services\Manufacturing Test Engineering\Projects\SVN\95002 - InnovATE Test Diagnostic\cvibuild.95002 Innovate Test Diagnostic\Debug\95003 FPGA Support.obj".
Build failed.
(3,537 Views)
Seems more of a CVI issue than LabVIEW FPGA.  Not sure I can see the error.
ALE Consultants
(3,519 Views)
I will post this on the LabWindows side.
(3,463 Views)
