LabWindows/CVI
Understanding Callbacks
How below callback working i mean how i will get data in Eventdat1,eventdata1,void *callbackData
is it it using file mapping technique?
Example:int CVICALLBACK HWAssignmentPnCallback (int panel, int event, void *callbackData,
int eventData1, int eventData2)
Message 11 of 13
(946 Views)
Hi sudhirvasudevacahrya,
I'm still not exactly sure what you're asking, but maybe some of the following documentation and examples will help you out.
https://decibel.ni.com/content/docs/DOC-25363
http://forums.ni.com/t5/LabWindows-CVI/How-can-I-use-void-callbackData/td-p/16369
http://www.ni.com/example/26225/en/
Andy F.
Applications Engineering
Message 12 of 13
(933 Views)
@engine_motor wrote:
how callback is working....is it using filemapping??
It might, but it is very unlikely and should not concern you in the least. What is your problem, if you have any?
Rolf Kalbermatter
My Blog
Message 13 of 13
(847 Views)
