I don't completely understand what the problem is. For example, what do you mean by "fields"? Do you mean CVI UI controls? Or do you mean text? Since CVI 5.0 was released more than four years ago, I would strongly suggest that you contact our technical support Engineers at
Request Support. They will be able to hel you decide if this is a bug in CVI 5.0 or if it's something related to your project. If it's the former, then it has probably been fixed in a newer version. If it's the latter, our Applications Engineers can help you with your code.
Best Regards,
Azucena Perez
NI
