08-18-2016 09:22 PM
Dose the CVI support "#pragma comment" now? when i use this command, the program dose not report any message, but not include the lib too.
08-22-2016 02:51 AM
Please refer to the following links about "#pragma comment":
http://ae.natinst.com/public.nsf/web/searchinternal/620a22abb2ba8148862570b70077aeef?OpenDocument
08-22-2016 07:44 AM
Hello jennygo,
your links seems not to work...
08-22-2016 08:10 PM
Pragma is a standardized form of comment which has meaning to a compiler. It may use a special syntax or a specific form within the normal comment syntax. A pragma usually conveys nonessential information, often intended to help the compiler to optimize the program.
See page 1-4 of the LabWindows/CVI Programmer Reference Manual for more information on using pragma comments in LabWindows/CVI.
Here is the Link of the reference manual :http://digital.ni.com/manuals.nsf/websearch/C01A6FD02234E93486256ABD0075CDC4?OpenDocument
08-23-2016 08:02 PM
hi,
i read the pdf and don't find any about "pragma comment". do you sure this command work in CVI? i think this command does not work in CVI.
08-23-2016 11:08 PM
