LabWindows/CVI
activeX controller for MS-word not working
 used activeX controller wizard to control MS-Word  and successfully created it with 'per property' compatibilty options.  i just simply tried to launch word application using function(Word_NewApplication (NULL, 1, LOCALE_NEUTRAL, 0, &appHandle);) it doesnt works for me inspite of returning return error value of '0' means success.   do i need something before using this function/API.
Please kindly help me in this regard...... i am new to this....please provide any helpful manual/tutorial for activeX ...
(3,036 Views)
Hi faisaldin,
If you look at your Task Manager after running the code you have listed in your post, you should see an instance of WINWORD.EXE running as a process.  This is because you are, in fact, opening a new instance of Word, but you must set it to be visible in order to see it.  This can be done with the Word_ApplicationSetVisible function.  For instance, your code would look something like the following:
Word_ApplicationSetVisible (appHandle, NULL, VTRUE);
This will make Microsoft Word visible for you.  Also, for more information regarding ActiveX controls in LabWindows/CVI, please look at the link I have posted below.  I hope this helps, faisaldin!
Programming with ActiveX Controls
Taylor G.
Product Support Engineer
www.ni.com/support
(3,020 Views)
