01-10-2017 09:38 AM - edited 01-10-2017 09:39 AM
Following the suggestion from Roberto here I enabled "Automatically save copy of UIR as TUI file" in CVI 2015 SP1. This simplifies the handling of UI files in git.
I have enabled the "auto backup" feature too, as shown below:
I've just noticed that there is at least one condition when CVI automatically saves a copy of the .tui file. I don't know exactly which is this condition: time interval, before compiling, before debugging, other, ...
I suppose that this happens when an .uir has been edited and not saved yet. In this case, the file is saved appending "~hhmmss" before the extension.
These files are not deleted when I save the .uir file pressing the button.
And this is annoying because git finds new file to track and I must manually delete (or exclude from tracking) them.
Is this an expected behavior?
If not, is it possible to fix this?
Solved! Go to Solution.
01-13-2017 07:10 AM
I have the same problem. After long programming sessions there can be hundreds of tui files strewn around the directory...
01-17-2017 08:36 AM
NI technical support confirmed this is a bug.
CAR #624635 has been opened for this issue.
05-29-2017 08:12 AM - last edited on 11-17-2024 05:41 PM by Content Cleaner
This CAR is marked as fixed in LabWindows/CVI 2017 Bug Fix Information
