LabWindows/CVI
change the value of an item in .ini file
I have a question regarding .ini files.
I have a .ini file with multiple sections each one contains different items like this :
[PORTCOM]
portNumber=38
baudRate=9600
parity=0
[DOUCHETTE]
LecteurCodeBarre_PortCom= 7
NbrTestRefDummy = 100
I can perfectly read every item's values.
I want to change the "NbrTestRefDummy" value and write instead a new value. So I made a Numeric to write the value I want and a command Button to change the initial value in the .ini file with the new value taped in the Numeric.
My code is like this :
int CVICALLBACK CMD_POSTE_INI_2 (int panel, int control, int event,void *callbackData, int eventData1, int eventData2)
static IniText handleFichierIni = 0;
static char g_fileName[MAX_PATHNAME_LEN];
switch (event)
case EVENT_COMMIT:
GetCtrlVal(panel,PANEL_SAIS_NV_NBR,&NV_Valeur);
GetDir ( RepertoireTravail);
sprintf(g_fileName,"%s\\Config.ini",RepertoireTravail);
handleFichierIni = Ini_New (1);
Ini_PutInt (handleFichierIni, "DOUCHETTE", "NbrTestRefDummy", NV_Valeur);
Ini_WriteToFile (handleFichierIni, g_fileName);
Ini_Dispose (handleFichierIni);
break;
return 0;
My problem is when the button is clicked, I have all the .ini file sections and items deleted and I only find the item that I changed its value with the new value ( here "NbrTestRefDummy").
my .ini file is like this :
[DOUCHETTE]
NbrTestRefDummy = 200
Could you please help me with this? I don't need to delete all the sections and items in the file. I need just to change the value of one item only.
(2,482 Views)
Accepted by topic author ch1994
This is obvious if you think to it: the instrument writes to disk what you have prepared in the IniFileobject, that is just the single field you have handled.
Simply read the file with Ini_ReadFromFile immediately after creating the IniFile object, next update the value you want and finally write the object to disk.
(2,467 Views)
Exactly this is what I've done and it works.
Thank you Roberto.
(2,436 Views)
