05-17-2017 08:11 AM
i can't have the input parameter RES after i build the DLL .
/******** INIT CAN Callback **************/ char* init_can (int Port_CAN,char* RES) { unsigned char target[20]={0}; char msg[512] ; int state=0; strcpy(DEVICE,"COM6"); //TD=OpenComConfig(Port_CAN,DEVICE,57600, 2, 8, 1, 0, 0); //COM pour la passerelle CAN TD=OpenComConfig(Port_CAN,DEVICE,9600, 2, 8, 1, 0, 0); if(TD != 0) { printf ("port not open\n" ); goto END; } FlushInQ(Port_CAN); FlushOutQ(Port_CAN); ComWrtByte(Port_CAN,0x88); ComWrtByte(Port_CAN,0x55); ComWrtByte(Port_CAN,0x06); ComWrtByte(Port_CAN,0x21); ComWrtByte(Port_CAN,0xC3); ComWrtByte(Port_CAN,0x3A); ComWrtByte(Port_CAN,0xFA); ComWrtByte(Port_CAN,0xF9); ComRd(Port_CAN,Reponse,20); memcpy(target,Reponse,5); strcpy (msg, "String ="); for (i = 0; i <5;i++) { sprintf (msg, "%s 0x%X", msg, target[i]); } strcat (msg, "\n"); printf(msg); RES=msg ; if(Reponse[3]==0x41) { printf (" INIT VITESSE CAN SUCCESS\n "); state++; Delay(1); } else { printf ( " ERROR CAN INIT VITESSE\n "); CloseCom(Port_CAN); goto END; } FlushInQ(Port_CAN); FlushOutQ(Port_CAN); ComWrtByte(Port_CAN,0x88); ComWrtByte(Port_CAN,0x55); ComWrtByte(Port_CAN,0x05); ComWrtByte(Port_CAN,0x20); ComWrtByte(Port_CAN,0xFE); ComWrtByte(Port_CAN,0x01); ComWrtByte(Port_CAN,0x07); ComRd(Port_CAN,Reponse,5); if(Reponse[3]==0x46) { printf (" SYNCHRO RS232 SUCCESS\n "); state++; Delay(1); } else { printf ( " ERROR CAN SYNCHRO RS232\n "); CloseCom(Port_CAN); goto END; } CloseCom(Port_CAN); OpenComConfig(Port_CAN, DEVICE, 57600, 2, 8, 1, 0, 0); // COM pour la passerelle CAN 115200 FlushInQ(Port_CAN); //FlushOutQ(Port_CAN); ComWrtByte(Port_CAN,0x88); ComWrtByte(Port_CAN,0x55); ComWrtByte(Port_CAN,0x03); ComWrtByte(Port_CAN,0x2B); ComWrtByte(Port_CAN,0xF5); ComRd(Port_CAN,Reponse,5); if(Reponse[3]==0x46) { printf (" TEST RS232 SUCCESS\n "); state++; Delay(1); } else { printf ( " ERROR CAN TEST RS232\n "); CloseCom(Port_CAN); goto END; } // INIT REGISTER FlushInQ(Port_CAN); FlushOutQ(Port_CAN); ComWrtByte(Port_CAN,0x88); ComWrtByte(Port_CAN,0x55); ComWrtByte(Port_CAN,0x05); ComWrtByte(Port_CAN,0x23); ComWrtByte(Port_CAN,0xFF); ComWrtByte(Port_CAN,0xFF); ComWrtByte(Port_CAN,0xFB); // RESET Can Reception Buffer FlushInQ(Port_CAN); FlushOutQ(Port_CAN); ComWrtByte(Port_CAN,0x88); ComWrtByte(Port_CAN,0x55); ComWrtByte(Port_CAN,0x03); ComWrtByte(Port_CAN,0x2D); ComWrtByte(Port_CAN,0xF3); //Time maxi beetween 2 char is 200 ms ( on RS232 link) FlushInQ(Port_CAN); FlushOutQ(Port_CAN); ComWrtByte(Port_CAN,0x88); ComWrtByte(Port_CAN,0x55); ComWrtByte(Port_CAN,0x04); ComWrtByte(Port_CAN,0x2E); ComWrtByte(Port_CAN,0x14); ComWrtByte(Port_CAN,0xE3); // Can Message not acknowledge request FlushInQ(Port_CAN); FlushOutQ(Port_CAN); ComWrtByte(Port_CAN,0x88); ComWrtByte(Port_CAN,0x55); ComWrtByte(Port_CAN,0x03); ComWrtByte(Port_CAN,0x29); ComWrtByte(Port_CAN,0xF7); if(state==3) { printf (" CAN INIT SUCCESS...PLEASE PRESS BSI ON\n"); } else { printf ( "ERROR CAN INIT\n"); } END: return RES; }
05-17-2017 08:23 AM
I suppose this is because you are assigning to RES the address of the variable msg which is local to the function and at its end it is no more valid. Try with memcpy instead.
05-17-2017 09:13 AM
i try it but still doesn't work any other suggestions please
05-17-2017 09:51 AM
This structure works in a compiled executable:
char * myFunction (char * msg) { char buf[32]; // Manipulate the string strcpy (buf, "Hello world!"); // Save the string strcpy (msg, buf); // Return the string return msg; }
I never tried to do the same in a DLL and I cannot test it now, but I suppose should work as well.
05-20-2017 11:05 AM
still have the same problem i can't have the Input /Output paremeter RES after i build the DLL als here the buffer type is unsigned char not const char so alawys i have an error with strcpy .
i need this function to return the paremeter msg
char* init_can (int Port_CAN, char* RES ) { unsigned char target[20]={0}; char msg[512] ; int state=0; strcpy(DEVICE,"COM6"); //TD=OpenComConfig(Port_CAN,DEVICE,57600, 2, 8, 1, 0, 0); //COM pour la passerelle CAN TD=OpenComConfig(Port_CAN,DEVICE,9600, 2, 8, 1, 0, 0); if(TD != 0) { printf ("port not open\n" ); goto END; } FlushInQ(Port_CAN); FlushOutQ(Port_CAN); ComWrtByte(Port_CAN,0x88); ComWrtByte(Port_CAN,0x55); ComWrtByte(Port_CAN,0x06); ComWrtByte(Port_CAN,0x21); ComWrtByte(Port_CAN,0xC3); ComWrtByte(Port_CAN,0x3A); ComWrtByte(Port_CAN,0xFA); ComWrtByte(Port_CAN,0xF9); ComRd(Port_CAN,Reponse,20); memcpy(target,Reponse,5); strcpy (msg, "String ="); for (i = 0; i <5;i++) { sprintf (msg, "%s 0x%X", msg, target[i]); } strcat (msg, "\n"); printf(msg); strcpy (RES,msg); if(Reponse[3]==0x41) { printf (" INIT VITESSE CAN SUCCESS\n "); state++; Delay(1); } else { printf ( " ERROR CAN INIT VITESSE\n "); CloseCom(Port_CAN); goto END; } FlushInQ(Port_CAN); FlushOutQ(Port_CAN); ComWrtByte(Port_CAN,0x88); ComWrtByte(Port_CAN,0x55); ComWrtByte(Port_CAN,0x05); ComWrtByte(Port_CAN,0x20); ComWrtByte(Port_CAN,0xFE); ComWrtByte(Port_CAN,0x01); ComWrtByte(Port_CAN,0x07); ComRd(Port_CAN,Reponse,5); if(Reponse[3]==0x46) { printf (" SYNCHRO RS232 SUCCESS\n "); state++; Delay(1); } else { printf ( " ERROR CAN SYNCHRO RS232\n "); CloseCom(Port_CAN); goto END; } CloseCom(Port_CAN); OpenComConfig(Port_CAN, DEVICE, 57600, 2, 8, 1, 0, 0); // COM pour la passerelle CAN 115200 FlushInQ(Port_CAN); //FlushOutQ(Port_CAN); ComWrtByte(Port_CAN,0x88); ComWrtByte(Port_CAN,0x55); ComWrtByte(Port_CAN,0x03); ComWrtByte(Port_CAN,0x2B); ComWrtByte(Port_CAN,0xF5); ComRd(Port_CAN,Reponse,5); if(Reponse[3]==0x46) { printf (" TEST RS232 SUCCESS\n "); state++; Delay(1); } else { printf ( " ERROR CAN TEST RS232\n "); CloseCom(Port_CAN); goto END; } // INIT REGISTER FlushInQ(Port_CAN); FlushOutQ(Port_CAN); ComWrtByte(Port_CAN,0x88); ComWrtByte(Port_CAN,0x55); ComWrtByte(Port_CAN,0x05); ComWrtByte(Port_CAN,0x23); ComWrtByte(Port_CAN,0xFF); ComWrtByte(Port_CAN,0xFF); ComWrtByte(Port_CAN,0xFB); // RESET Can Reception Buffer FlushInQ(Port_CAN); FlushOutQ(Port_CAN); ComWrtByte(Port_CAN,0x88); ComWrtByte(Port_CAN,0x55); ComWrtByte(Port_CAN,0x03); ComWrtByte(Port_CAN,0x2D); ComWrtByte(Port_CAN,0xF3); //Time maxi beetween 2 char is 200 ms ( on RS232 link) FlushInQ(Port_CAN); FlushOutQ(Port_CAN); ComWrtByte(Port_CAN,0x88); ComWrtByte(Port_CAN,0x55); ComWrtByte(Port_CAN,0x04); ComWrtByte(Port_CAN,0x2E); ComWrtByte(Port_CAN,0x14); ComWrtByte(Port_CAN,0xE3); // Can Message not acknowledge request FlushInQ(Port_CAN); FlushOutQ(Port_CAN); ComWrtByte(Port_CAN,0x88); ComWrtByte(Port_CAN,0x55); ComWrtByte(Port_CAN,0x03); ComWrtByte(Port_CAN,0x29); ComWrtByte(Port_CAN,0xF7); if(state==3) { printf (" CAN INIT SUCCESS...PLEASE PRESS BSI ON\n"); } else { printf ( "ERROR CAN INIT\n"); } END: return RES ; }
i try to call this DLL from Teststand and Labview and still the same problem
05-20-2017 05:46 PM
Well, since your problem lies in the interaction between CVI and TestStand, it seems to me that the best place where to ask is the TestStand board. There are several discussions there on this subject, look for example at this aswer from Josh and the KnowledgeBase article he links. Hope this makes sense for you, it doesn't for me as I'm not using TestStand.
On the CVI side, I don't understand why you don'use ComWrt and use a series of ComWrtByte instead. And finally, I suggest you to pass -1 to OutputQueueSize in OpenComConfig in order to exclude the use of the output buffer in serial communication and have a more responsive system.
05-20-2017 06:39 PM
thank you for your response
i tried to import the DLL in Labview and it work
in the CVI side i change only the return type of the funcyion in char*
05-31-2017 03:39 AM
Hi Mr Roberto
i have problem with this function i can't read the true value of the received frame
this is the function :
PSA MODE
RAZ Buffer Reception Can
CAN :->88 55 03 2D F3
CAN : Envoi DIAG ON CAN Frame 2.A
CAN :->88 55 0E 22 07 65 08 02 10 03 FF FF FF FF FF 75
CAN : Demande Nb Message Can
CAN :->88 55 03 2C F2
CAN6 :<-88 55 05 47 00 00 9F :OK
CAN6 :<-88 55 05 47 00 01 9E :OK
CAN : Demande Message Can
CAN :->88 55 03 24 FA
CAN6 :<-88 55 09 40 06 65 03 02 50 03 A5 :OK
CAN -> N° message Can1
CAN :<-025003A5 : OK ( i want the fuction to return this value )
//PSA_MODE char* PSA_MODE (int Port_CAN ) { unsigned char target[20]={0}; char msg[512]; //1 FlushInQ(Port_CAN); //FlushOutQ(Port_CAN); ComWrtByte(Port_CAN,0x88); ComWrtByte(Port_CAN,0x55); ComWrtByte(Port_CAN,0x03); ComWrtByte(Port_CAN,0x2D); ComWrtByte(Port_CAN,0xF3); //2 FlushInQ(Port_CAN); //FlushOutQ(Port_CAN); ComWrtByte(Port_CAN,0x88); ComWrtByte(Port_CAN,0x55); ComWrtByte(Port_CAN,0x0E); ComWrtByte(Port_CAN,0x22); ComWrtByte(Port_CAN,0x07); ComWrtByte(Port_CAN,0x65); ComWrtByte(Port_CAN,0x08); ComWrtByte(Port_CAN,0x02); ComWrtByte(Port_CAN,0x10); ComWrtByte(Port_CAN,0x03); ComWrtByte(Port_CAN,0xFF); ComWrtByte(Port_CAN,0xFF); ComWrtByte(Port_CAN,0xFF); ComWrtByte(Port_CAN,0xFF); ComWrtByte(Port_CAN,0xFF); ComWrtByte(Port_CAN,0x75); //3 FlushInQ(Port_CAN); //FlushOutQ(Port_CAN); ComWrtByte(Port_CAN,0x88); ComWrtByte(Port_CAN,0x55); ComWrtByte(Port_CAN,0x03); ComWrtByte(Port_CAN,0x2C); ComWrtByte(Port_CAN,0xF2); ComRd(Port_CAN,Reponse,20); if(Reponse[3]==0x47) { printf ("PASSED_1 \n "); Delay(1); } else { printf ( "NOT_PASSED_1 \n "); } //3' FlushInQ(Port_CAN); //FlushOutQ(Port_CAN); ComWrtByte(Port_CAN,0x88); ComWrtByte(Port_CAN,0x55); ComWrtByte(Port_CAN,0x03); ComWrtByte(Port_CAN,0x2C); ComWrtByte(Port_CAN,0xF2); ComRd(Port_CAN,Reponse,20); if(Reponse[3]==0x47) { printf ("PASSED_1' \n "); Delay(1); } else { printf ( "NOT_PASSED_1' \n "); } //4 FlushInQ(Port_CAN); //FlushOutQ(Port_CAN); ComWrtByte(Port_CAN,0x88); ComWrtByte(Port_CAN,0x55); ComWrtByte(Port_CAN,0x03); ComWrtByte(Port_CAN,0x24); ComWrtByte(Port_CAN,0xFA); ComRd(Port_CAN,Reponse,20); ; memcpy(target,Reponse,10); strcpy (msg,""); for (i = 0; i <10;i++) { sprintf (msg, "%s%X", msg, target[i]); } strcat (msg, "\n"); printf(msg); if(Reponse[3]==0x40) { printf ("PASSED_2 \n "); Delay(1); } else { printf ( "NOT_PASSED_2 \n "); ; } return msg; }
this the result any help please
05-31-2017 06:20 AM
'msg' variable is local to the function and is released after the function ends, which means the caller can receive an invalid string. Have you tried passing the string to manipulate to the function as I told you before?
Try doing so and see if the string is correctly returned calling it from CVI: if it works, then the problem is likely to lie in how the function is defined in TestStand, which I cannot discuss.
05-31-2017 08:02 AM
Thank you for your response
This is my try but still doasen't work, i can't undrestand how it works in the Init can Function and no in this one
After i build the dll i'm calling it from labview it works properly in the init function return the msg received without adding a new paremeter like Input /Outpout RES
//PSA_MODE char *PSA_MODE (int Port_CAN ,char* RES) { unsigned char target[20]={0}; char msg[512]; //1 FlushInQ(Port_CAN); //FlushOutQ(Port_CAN); ComWrtByte(Port_CAN,0x88); ComWrtByte(Port_CAN,0x55); ComWrtByte(Port_CAN,0x03); ComWrtByte(Port_CAN,0x2D); ComWrtByte(Port_CAN,0xF3); //2 FlushInQ(Port_CAN); //FlushOutQ(Port_CAN); ComWrtByte(Port_CAN,0x88); ComWrtByte(Port_CAN,0x55); ComWrtByte(Port_CAN,0x0E); ComWrtByte(Port_CAN,0x22); ComWrtByte(Port_CAN,0x07); ComWrtByte(Port_CAN,0x65); ComWrtByte(Port_CAN,0x08); ComWrtByte(Port_CAN,0x02); ComWrtByte(Port_CAN,0x10); ComWrtByte(Port_CAN,0x03); ComWrtByte(Port_CAN,0xFF); ComWrtByte(Port_CAN,0xFF); ComWrtByte(Port_CAN,0xFF); ComWrtByte(Port_CAN,0xFF); ComWrtByte(Port_CAN,0xFF); ComWrtByte(Port_CAN,0x75); //3 FlushInQ(Port_CAN); //FlushOutQ(Port_CAN); ComWrtByte(Port_CAN,0x88); ComWrtByte(Port_CAN,0x55); ComWrtByte(Port_CAN,0x03); ComWrtByte(Port_CAN,0x2C); ComWrtByte(Port_CAN,0xF2); ComRd(Port_CAN,Reponse,20); if(Reponse[3]==0x47) { printf ("PASSED_1 \n "); Delay(1); } else { printf ( "NOT_PASSED_1 \n "); } //3' FlushInQ(Port_CAN); //FlushOutQ(Port_CAN); ComWrtByte(Port_CAN,0x88); ComWrtByte(Port_CAN,0x55); ComWrtByte(Port_CAN,0x03); ComWrtByte(Port_CAN,0x2C); ComWrtByte(Port_CAN,0xF2); ComRd(Port_CAN,Reponse,20); if(Reponse[3]==0x47) { printf ("PASSED_1' \n "); Delay(1); } else { printf ( "NOT_PASSED_1' \n "); } //4 FlushInQ(Port_CAN); //FlushOutQ(Port_CAN); ComWrtByte(Port_CAN,0x88); ComWrtByte(Port_CAN,0x55); ComWrtByte(Port_CAN,0x03); ComWrtByte(Port_CAN,0x24); ComWrtByte(Port_CAN,0xFA); ComRd(Port_CAN,Reponse,20); ; memcpy(target,Reponse,10); strcpy (msg,""); for (i = 0; i <10;i++) { sprintf (msg, "%s%X", msg, target[i]); } strcat (msg, "\n"); strcpy(RES ,msg); printf(msg); if(Reponse[3]==0x40) { printf ("PASSED_2 \n "); Delay(1); } else { printf ( "NOT_PASSED_2 \n "); ; } return RES ; }
