LabWindows/CVI
cvi sql command question
The value must be returned through the command in the picture.
Please tell me how to implement it with CVI sql command.
thank you
(302 Views)
First of all you must install the CVI SQL Toolkit.
After doing that you'll find a set of examples that show how to query a database and retrieve values: you can find them using the Example Finder that you can access via Help >> Find Examples... menu item in the CVI IDE.
(268 Views)
