01-15-2009 11:52 AM - edited 01-15-2009 11:53 AM
I'm using CVI 9.0.
This is not really a big issue, but an annoyance.
When I create a distribution (build a release) I am working with files on a network drive (in Clearcase, if that matters).
I usually have my project mounted on Z: (i.e. Z:\cctd\test_sw\proj1),
but with others working on this, or needing to do something in a different version (mounted on a different drive), I may need to work with a version on the X: drive (i.e. X:\cctd\test_sw\proj1).
The problem I have with this is that the files listed in the distribution package have hard coded drive mappings, so if I switch from the Z version to the X verison, the files listed in (Build->Distributions->Edit proj) the Files tab, in the bottom half the "Installation Files & Directories" have a lot of the files in red, because they are from the distribution from the Z drive and have sizes 0, they are not available.
I then have to manually remove and then add the files back in.
I'd like to have some way to not have to mess with this.
I'd like a drive setting that I can change and it would adjust each file, or it would just use some sort of relative path or something.
Anyone know how to work around this?
01-15-2009 02:25 PM
For files added to the distribution in the Files tab, relative paths are only kept if the files are in the project. So, for example, if you are distributing a UIR, it is likely in your project tree, and so CVI looks for that file relative to the .prj file. For your use case, I would suggest adding all the files that are showing up red to your project tree. You could create a folder in your project tree named "Distribution Files" and add them there.
Let me know if that solution works for you, or else maybe we can think of a better solution to implement for a future version.
Mert A.
01-21-2009 02:26 PM
It worked to add the files to the project.
Funny I didn't think of that before.
