LabWindows/CVI
hovering activates command button
Accepted by mzimmers
This is exactly the way the package works... Smiley Wink
A control callback receives all events fired: it's up to you to tailor the callback code so that only interesting events are handled, while the others are simply ignored (but the callback is indeed executed).
Message 11 of 18
(1,677 Views)
Thank you, Roberto. Now...is there any documentation that describes this behavior (and other stuff) at a conceptual level?
So far, my impression of the CVI documentation has been that it's pretty good for reference, but not so good for learning concepts. Is there perhaps some documentation I'm not aware of? For example, where would I have found the answer to this particular question?
Message 12 of 18
(1,671 Views)
Well, I must admit that most of my knowledge of CVI has been acquired on the way by reading documents, forum posts, tutorials and so on amd making a lot of tests: as far as I know there is not a complete conceptual document explaining CVI paradigms. A lot of informations can be found in the Programmer's Reference book in the help, but in the particular case we are discussing here you could have found some informations in this chapter of the User Interface Library help: Using Callback Functions to Respond to User Interface Events
Message 13 of 18
(1,668 Views)
That's a helpful page, Roberto...thanks.
One thing I'm still trying to fully understand is the use of callbackData. I notice in the examples on that page, that the pointer didn't seem to be used anywhere. Is the callback routine supposed to do something with that? In my example above, my callbackData value is NULL, so I'm not sure what I'm supposed to do with it.
Message 14 of 18
(1,663 Views)
callbackData parameter is designed completely for programmer's use: the system does anything with it, except passing it to the control function.
I can give you an example of how I use it: I often have to develop programs that take care of several independent equipments, each of them must be setup, started and stopped. I normally have a list of buttons in my main panel, one per each equipment, to which I have installed as callbackData the equipment ID; the callback of these buttons, unique for all of them, displays a status window for the selected equipment, which it discriminates via callbackData value.
Again, when displaying the status window I install the same callbackData on settings, start and stop buttons, and so again one single callback can operate on every equipment simply using callbackData value to discriminate which is the equipment to address.
There is no limit on callbackData parameter usage, wolfgang has pointed you to fileBrowser custom control which intensively uses it; my example is probably simpler but easier to understand.
Message 15 of 18
(1,644 Views)
Hi, Roberto -
I think I understand the principle of the field; it's more the mechanics of using it that I still don't get. This is considered an input to the callback routine, right? So...how do I "load" that field with data before the callback is called? I put breakpoints in my CBs and the value of the pointer is NULL.
Message 16 of 18
(1,616 Views)
callbackData is left for programmer's needs, so it's the programmer that is in charge of filling and retrieving values from the variable.
To set a value in callbackdata parameter you must either do this:
SetCtrlAttribute (panelHandle, PANEL_CONTROLID, ATTR_CALLBACK_DATA, (void *)value);
or this
InstallCtrlCallback (panelHandle, PANEL_CONTROLID, eventFunction, (void *)callbackData);
To retrieve a value from the variable if inside the control callback you simply have to cast it to appropriate data type:
int CVICALLBACK myCallbackFunction (int panel, int control, int event,
void *callbackData, int eventData1, int eventData2)
	int		value;
	if (event != EVENT_COMMIT) return 0;
	value = (int)callbackData;
	// Other code here
	return 0;
If outside of the control callback, you must first read it in a void * variable and then cast it to the appropriate type:
void	*cbkd;
int		value;
GetCtrlAttribute (panelHandle, PANEL_CONTROLID, ATTR_CALLBACK_DATA, &cbkd);
value = (int)cbkd;
As already pointed out in one of the posts linked by wolfgang, if used as a pointer callbackData must point to an object that is still valid when it is retrieved: that is, you cannot point it to a variable local to a function and retrieve it in another function.
Message 17 of 18
(1,610 Views)
Ahh! There's the ingredient I was missing. The SetCtrlAttribute() routine, along with the ATTR_CALLBACK_DATA parameter, was the Rosetta Stone.
Thank you SO much, Roberto...this helps a great deal.
Message 18 of 18
(1,602 Views)
