LabWindows/CVI
how to call a button’s click event programmatically
Dear All,
I would like to know how to call a button’s click event
programmatically in LabWindows/CVI.
Thank you very much,
Mariela.
(6,285 Views)
Accepted by topic author prodna
Either you directly call the button callback or (better) use CallCtrlCallback passing the appropriate event (normally EVENT_COMMIT: it depends on which event you are handling inside the control callback).
(6,280 Views)
I have a follow up question.
the prototype is
int CallCtrlCallback (int Panel, int Ctrl, int Event, int EventData1, int EventData2, int *Return_Value);
For an event = EVENT_COMMIT what are the meaning of values EventData1 and EventData2? Or do I just set them to NULL?
(6,195 Views)
I have never checked what the values are when I get an EVENT_COMMIT event but I have used this function and simply set both of those to zero.
Works fine, I do know that for mouse clicks (not commits!) those are populated with the mouse pointer coordinates.
Martin Fredrickson
Test Engineer
Northrop Grumman
Advanced Systems and Products
San Diego, CA 92128
(6,172 Views)
Meaning of eventData parameters is listed in userint.h where events are defined. Several events have associated eventData values (some of them only when fired for specific control types).
(6,170 Views)
