LabWindows/CVI
how to set excel column width
I am using ExcelRpt_SetCellRangeAttribute function to set the width of a cell in excel.
What vale I should pass to set the width for example 50, I have tried to pass values  but its not working.
As a result of passing values the column containing that cell am specifying is getting hided.
pls help me out
Message 1 of 8
(5,914 Views)
The value you are giving to the function, is it an integer? In that case, try to give the value in the form of a double.
Message 2 of 8
(5,893 Views)
Hi Sumit,
I have tried with long,float,int & double but its not working.
I am using function
ExcelRpt_SetCellRangeAttribute(worksheethandle,Rangevalue,ER_CR_ATTR_COLUMN_WIDTH,widthvalue)
Message 3 of 8
(5,884 Views)
Message 4 of 8
(5,874 Views)
I have gone through this....its showing data type decimal for widthvalue, am trying to pass same but as a result the whole column is getting hided.
Message 5 of 8
(5,870 Views)
Accepted by a kumar
Hi!
I modified the example project "excel2000dem.prj" come with LabWindows/CVI installation to see if I can set the column width as you asked.
Following partial code successfully set the column width to 15.0 points in MS Excel 2003.
#define EXCEL_ARRAY_OF_CELLS "A2:H11"
static ExcelObj_App               ExcelAppHandle = 0;
static ExcelObj_Workbooks         ExcelWorkbooksHandle = 0;
static ExcelObj_Workbook          ExcelWorkbookHandle = 0;
static ExcelObj_Window            ExcelWindowHandle = 0;
static ExcelObj_Sheets            ExcelSheetsHandle = 0;
static ExcelObj_Worksheet         ExcelWorksheetHandle = 0;
static ExcelObj_Range             ExcelRangeHandle = 0;
static VARIANT MyCellRangeV;
....... (I assume you have an opened Excel application and a Workbook active already) .....
    // Get Active Workbook Sheets
    error = Excel_GetProperty (ExcelAppHandle, NULL, Excel_AppSheets, CAVT_OBJHANDLE, &ExcelSheetsHandle);
    // Get First Sheet
    error = Excel_SheetsItem (ExcelSheetsHandle, NULL, CA_VariantInt(1), &ExcelWorksheetHandle);
    // Make First Sheet Active - should already be active
    error = Excel_WorksheetActivate (ExcelWorksheetHandle, NULL);
    // Open new Range for Worksheet
    error = CA_VariantSetCString (&MyCellRangeV, EXCEL_ARRAY_OF_CELLS);
    error = Excel_WorksheetRange (ExcelWorksheetHandle, NULL, MyCellRangeV, CA_DEFAULT_VAL, &ExcelRangeHandle);
    // Make range Active
    error = Excel_RangeActivate (ExcelRangeHandle, &ErrorInfo, NULL);
   // Set column width
    error = Excel_SetProperty (ExcelRangeHandle, &ErrorInfo, Excel_RangeColumnWidth, CAVT_DOUBLE, 15.0);
Let us know if this works for you.
Message 6 of 8
(5,848 Views)
I modified my code with these function its working.
Message 7 of 8
(5,824 Views)
For what it's worth, simply passing a float value as the column width does work for me:
ExcelRpt_SetCellRangeAttribute(workSheet, "A1", ER_CR_ATTR_COLUMN_WIDTH, 25.0));
The advantage of this over the proposed solution is that you then don't have to attach the excel2000.h at all and instead use the ExcelReport.h exclusively.
Message 8 of 8
(4,541 Views)
