LabWindows/CVI
no sdk installing option for CVI 2009
When trying to build a dll from a project ,that was created (and working fine) with CVI 8.0 using winSDK Functions (winInet.lib)
with CVI 2009
i get errors "Redeclaration of FILETIME". The winInet header and the winInet.lib in the project are still the same as found in SDK for CVI 8.0. I found no Option to install  some SDK from the DVD that installs CVI2009 ?
Are there Versions of cvi2009 that contain win SDK  and some that do not ?
Might be a silly question , but I found no hints concerning this topic .
Message 1 of 12
(5,351 Views)
Did you install CVI from a Developer Suite DVD?
If yes, you have to choose the "Custom Install" option instead of "Install", for the LabWindows/CVI item in the product tree of the suite installation.
(Just click on the small icon on the left and a small menu appears for this)
Otherwise, installation completes with defualt options which exclude SDK.
That's the case for 9.0, probably same applies to 2009.
This had also confused me while installing on my machine.
Message Edited by ebalci on 09-03-2010 01:59 PM
S. Eren BALCI
IMESTEK
Message 2 of 12
(5,349 Views)
I installed from a CVI2009 Platform DVD , using customized installation , but there were no SDK options
Message 3 of 12
(5,346 Views)
Well, then it may be a package type problem.
Which type of CVI licence do you have? base/full/professional?
There used to be a separation of this kind. Base version may not have the SDK option.
I do not have 2009 so I cannot verify this by myself.
S. Eren BALCI
IMESTEK
Message 4 of 12
(5,342 Views)
Accepted by topic author beethoven
Solved :  Installing - Option "Win SDK" is  now  "Install Win32 API" , which was excluded from my installation
Message 5 of 12
(5,337 Views)
The specific item you need to check after doing a customized installation is called "Interface to Win32 API".  This will install the full SDK.  I had just gone through this myself, and found it very confusing.
Message 6 of 12
(5,335 Views)
Sorry for the confusion caused by the name change. This was a request from Microsoft.
Luis
Message 7 of 12
(5,301 Views)
I'm moving to a new PC and am stumped on this one. Where do I select "Interface to Win32 API" in the image below?
Message 8 of 12
(4,872 Views)
Interestingly, when I dig out my older installation discs, I do get that option:
Explanations / suggestions welcome.
Message 9 of 12
(4,869 Views)
I noticed that when you install CVI 2009 for the first time, the option "Interface to Win32 API" is missing.
But after you installed CVI, if you use the same disks to repair or modify the installation, you can see this option.
I installed the Win32 API interface in this way.
Vix
In claris non fit interpretatio
Using LV from 7
Using LW/CVI from 6.0
Message 10 of 12
(4,849 Views)
