LabWindows/CVI
pass parameter to functions called from dll
Hi All,
I am interfacing a PMC-100 motor controller via Performax protocol using labwindows.
I need to link PerformaxCom.dll explicitly and call some functions from it. I am trying to call this function
BOOL fnPerformaxComOpen(IN DWORD dwDeviceNum, OUT HANDLE* pHandle);
- This function is used to open communication with the Performax USB module and to get communication handle. Index number starts from 0.
I tried this way to call another function which just have output and it worked. http://digital.ni.com/public.nsf/websearch/8AE57BDA995ACCB486256AEA0062B3C6?
But the problem is that I don't know how to pass parameter to it.
Thanks a lot!
Tianchi
(3,431 Views)
Accepted by topic author paly_Andrew
Tianchi:
If you want to explicitly link, you can look at this article: http://zone.ni.com/devzone/cda/tut/p/id/8503
It has a snippet of code which shows passing two parameters to a DLL function.
But regarding your statement that "I don't know how to pass parameter to it", in the example you reference, you are passing a parameter: it's just a string constant rather than a variable.
(3,416 Views)
Thank you, that link was helpful. I turned out that i didn't typedef the function right. So I could not pass two parameters to the function.
(3,393 Views)
