03-02-2022 04:49 AM
Hello i send CAN frames with PCAN UDS API.
need to send a sequence of 16 frames with ID E8 every 10ms. I therefore use a timer but as you can see on my screenshot some frames are not sent. this phenomenon is periodic. I do not understand why.
an extract
int main (int argc, char *argv[])
int ctrl;
if (InitCVIRTE (0, argv, 0) == 0) /* Needed if linking in external compiler; harmless otherwise */
return -1; /* out of memory */
if ((panelHandle = LoadPanel (0, "interface_finale.uir", PANEL)) < 0)
return -1;
#ifdef FORD
ctrl = NewCtrl (panelHandle, CTRL_TIMER, "", 1, 1);
SetCtrlAttribute (panelHandle, ctrl, ATTR_INTERVAL,0.100);
SetCtrlAttribute (panelHandle, ctrl, ATTR_ENABLED, 1);
SetCtrlAttribute (panelHandle, ctrl, ATTR_CALLBACK_FUNCTION_POINTER, timerCallback);
#else
#endif
#ifdef FIAT
SetCtrlAttribute (panelHandle, ctrl, ATTR_INTERVAL,0.010);
SetCtrlAttribute (panelHandle, ctrl, ATTR_CALLBACK_FUNCTION_POINTER, FIATtimer);
/*ctrl = NewCtrl (panelHandle, CTRL_TIMER, "", 1, 1);
SetCtrlAttribute (panelHandle, ctrl, ATTR_CALLBACK_FUNCTION_POINTER, FIATtimer2);*/
#else
#endif
DisplayPanel (panelHandle);//display panel on scree
RunUserInterface ();//Runs the user interface and issues events to callback functions
return 0;
callback timer
unsigned char Fiatframe[129]={0x87,0x99,0x00,0x00,0x08,0x00,0x00,0xD1,
0x87,0x99,0x00,0x00,0x08,0x00,0x01,0xCC,
0x87,0x99,0x00,0x00,0x08,0x00,0x02,0xEB,
0x87,0x99,0x00,0x00,0x08,0x00,0x03,0xF6,
0x87,0x99,0x00,0x00,0x08,0x00,0x04,0xA5,
0x87,0x99,0x00,0x00,0x08,0x00,0x05,0xB8,
0x87,0x99,0x00,0x00,0x08,0x00,0x06,0x9F,
0x87,0x99,0x00,0x00,0x08,0x00,0x07,0x82,
0x87,0x99,0x00,0x00,0x08,0x00,0x08,0x39,
0x87,0x99,0x00,0x00,0x08,0x00,0x09,0x24,
0x87,0x99,0x00,0x00,0x08,0x00,0x0A,0x03,
0x87,0x99,0x00,0x00,0x08,0x00,0x0B,0x1E,
0x87,0x99,0x00,0x00,0x08,0x00,0x0C,0x4D,
0x87,0x99,0x00,0x00,0x08,0x00,0x0D,0x50,
0x87,0x99,0x00,0x00,0x08,0x00,0x0E,0x77,
0x87,0x99,0x00,0x00,0x08,0x00,0x0F,0x6A};
int enable_ex8=0;
int CVICALLBACK FIATtimer (int panel, int control, int event,
void *callbackData, int eventData1, int eventData2)
if (event != EVENT_TIMER_TICK) return 0;
if(enable_ex8==1)
status = UDS_MsgAlloc_2013(&FIAT_msg, config2,8);
for(i=0;i<8;i++)
FIAT_msg.msg.msgdata.isotp->data[i]=Fiatframe[j];
j=j+1;
if(j==64)
j=0;
status = UDS_Write_2013(PCANTP_HANDLE_USBBUS1, &FIAT_msg);
UDS_MsgFree_2013(&FIAT_msg);
return 0;
Thank you
03-02-2022 05:09 AM
CVI timers are not precise and can be interrupted by many things (like moving a window). At the very least you should be using asynchronous timers (they are almost a drop in replacement in terms of code). Search for asynctmr.fp
03-02-2022 07:19 AM
Merci
